71dusterjon
Well after much frustration I need to sell my truck. I bought the truck with 26,000mi and it now had 37,000 mi. Here is what the truck came with when i first got it:
-xmetal shifter
-paxton supercharger
-belanger headers
-4.10 gear *Stock*
-pioneer avic-z2 double din (has xm radio, bluetooth, ipod, cd changer, aftermarket amp, back up camera)
-redone the seats in suede
-magnaflow exhaust
-secondary cat delete
-high flow cats
Here are the things i did while i've had the truck:
-routed cables for ipod to armrest
-vibration damper on transmission (w/o will cause rear seal to leak)
-new trans beaings
-new bronze shifter fork pads
-new billet syncro keys for 3/4
-painted the wheels
-new red top optima battery
-relocated battery to bed of truck
-painted intake/valve covers and headers
-painted interior piece red
-new oil cooler lines
-new *screamin demon coils*
-new ngk zfr6f-11 spark plugs
-new magnecor 8.5mm spark plug wires
-crankcase vent into exhaust
-4pt harnesses
-painted headlights, door handles, and mirrors
-ebc rotors and pads (at 30,000mi)
-had dc performance retune the truck because if was running too rich
Here is what is wrong with the truck:
-I parked the truck for a month to change oil cooler lines, paint the valve covers, intake and headers plus install a crankcase vent into the exhaust. When i started the truck up i got a knocking sound. I have only driven the truck about 5 miles ( that was to gas station and back to fill up plus got towed to my shop). I replace the coils, wires, and plugs to see if this would get rid of the knock, but it didn't. I also did a compression test:
1-115 2-115
3-110 4-145
5-100 6-145
7-80 8-65
9-45 10-80
I believe that the compression has always been low since i got the truck. I'm having the engine oil tested this week to see what exactly is going on. The engine will more than likely need to be pulled and rebuilt. The oil pressure is about 25lb at idle but should be close to 70lb.
The only damage to the truck was when i was going around a corner and the back end got loose causing me to tap a guard rail. The parts that had to be replaced were the driver side fender, driver side headlight, and bumper. I have pictures if you want.
I'm asking $20,000 and the truck will have to be towed because the engine isn't running correctly. Please pm if you have any questions or want more pictures.
-xmetal shifter
-belanger headers
-4.10 gear *Stock*
-magnaflow exhaust
-high flow cats
-new trans beaings
-painted the wheels
-4pt harnesses
1-115 2-115
3-110 4-145
5-100 6-145
7-80 8-65
9-45 10-80
