06 rec nav install
BadBoyM
Hell
hello all
i figured since it took me 3 hours to figure out how to get the bezel off i would post this so if any of you upgrade it could help.
to get the bezel off and gain access to the radio, pull up on the center console until it unclips. once this is done there are three 1/4 drive screws. once those are removed the whole console is out of the way. then there are two more 1/4 drive screws that releases the bottom molding behind the console. once those are removed the bottom and top molding will come off. underneath the bezel are two more screws. the bezel is held on only by those two screws and clips. after that its 4 screws to release the radio. the rec is all plug and play so this is actually about a 1 hour job. it took me 4hours because i took almost the whole dash off trying to find the release for the bezel.
Pics are worth a 1,000,000,000,000,000,000 Words
good idea when i get the new bezel wed i will take pics of taking it back apart again.
Thanks
Your Awesome :rock:
