1 little hose so many problems WTF
BLWNSRT
Member
So today I decide to drive my truck to work, bad idea so it sits allday out in 30c weather I warm it up let the A/C cool he interior for 10-15min so I make the left turn I always do lay into it and.... Bog Black smoke (should have been a diesel that bad) and no power at all.
Ok then I drive easy around the corner check for bad noises there are none runnin 10.0 at idle limp it back to work. I have no boost gauge no vacuum at all??? Look the plastic hose that tees off the intakethat goes to the map and boost gauge popped off map was still attached ok then. Have a boost gauge now still running kinda bad. So I drive home and have a bog around 1700-2200 light throttle. The more I drove home the better it got.
So did the PCM need to "fix" itself
I used the scanner to check the tps for a bad spot seems ok.
Should I just replace the tps anyways
The truck has 16900km on it so not much.
Mine hates ticking over for too long,makes it real boggy for a few miles.Normaly get the eml come on,even though it's running fine by then,I do the battery disconnect and she's ok :burnout:
i would have to install your Roe on my truck & run some tests to give ya a good answer
:aetsch::aetsch::aetsch::aetsch::elefant::elefant::elefant::elefant::rock::rock::rock::D
