i do, i run it straight and sometime mix 2cycle lube in it, nothing wrong with using it if the sensors are shut off, its about the best fuel you can use, its not a specific rpm only fuel and its not an high altitude only fuel, as iv said and has been told befor, an aircrafts hardest job is takeing off on a runway from dead stop to lift off, the engine is working its hardest on the ground, i been using it for years in cars trucks to high compression race engines, just check your plugs.
