12.69
onebadbee24_7
n/a no nitrous
its got to be in the wiring its not getting nitrous thru the nmu
got 8 videos
did you hook up and set the TPS so the green light is lit?
yep it was learned
the hemi throttle body only upens 95 percent at WOT
i opened it up to 100 percent 4.50 volts and throttle body only opens to 4.40-4.45 volts
where is the fuel tapped from? Your other post says it was working good ?
it was
but i played with it a lil bit thinking i should relearn it
