122 mm turbo
BAD-RC
Lexington, Ky
Turbonetics Releases New 122mm Billet Turbo - we call it the "Baby Killer" When you think the world of turbos for automotive use is at their biggest, we all get surprised again. Turbonetics has released their new TNX-122, 122 MM turbo. The kit is designed for top tier racing, such as, Pro Mods and really for diesel sled pulling competitions. “Diesels go for the most amount of boost you can possibly fit in an engineâ€￾, says Turbonetics Marketing Manager, Tyler Tanaka.
Compared against a Turbonetics T3 turbo
The turbo is capable of producing over 2500 horsepower, while supporting 50-60 PSI. The center section is an all-new billet piece. It allows Turbonetics to build a stronger internal bearing with a new, patented oiling system. Also, the compressor wheel is made from a billet 713C super-alloy. “When you run this much boost on a cast wheel, it can expand from the center and explode.â€￾ Tyler remarked. Regardless, make sure small animals are not present while in operation.
need to mount them in the bed expecially if you want twin turbos :D
Yea, but 10 psi blows the Viper motor up, so whats the point
wonder what size waste gate you need for that..a 55 gal drum?
yea no <edited> :p that think could suck ur arm up if the hood was open and someone revs the motor :D
