125 shot NOS
AWDisuzu
Valencia, CA
with stock ecu, not bad.
with DC stage 2 ecu - WHOOOAAA hold the eff on!
with race gas of course.
WHEEEEEEEEEEEEEE!
brad and I installed our NOS kits a week ago! i just hadn't really tried it out much.
ViperTruck2933 said:
Doesn't the Stage II flash pull too much timing to be safe with Nitrous?:dontknow:
i know what youre saying but the flash adds timing. so the more you spray the more you want to pull or reduce timing.
AWD......have you tried with both PCM's? Is the timing ramped up over stock with that stage II?
you mean add timing...but he said race gas..with good gas he doesn't need to pull timing with a small shot....
mauiSRT/10 said:
So whats the verdict on timing? Does the DC flash pull timing or add some in? I always thought it pulled some....but WTF do I know!:dontknow:
The stage II advances the timing :idea:
yea, the stage 2 advances the timing enough to ping with 91. I'm using 3 cans of torco with 20 gallons of 91 to make 100+ octaine.
Cool. I don't know very much (if anything) about running nitrous. I just thought that with the pinging (detonation) problems some people have experienced with the Stage II flash, that I would be VERY hesitant to run nitrous with the flash.
Makes sense that the higher octane would combat the detonation issue. :rock:
as for a comparison with the 125 shot and stock pcm vs stage 2.
with the stock pcm, activating the nos at 2500 rpm in 1st gear - tires chirp for about 1/2 a second then it chirps 2nd for about half a second
with the stage2, activating at 2500 rpm in 1st gear - tires light up but hook before going into 2nd. chirps 2nd for 2 seconds then hooks.
the 125 shot on a stock computer is just a little faster than a stage2 with no nos.
now order some Drag radials and get to the track!
Hey GRYSRT ,
I was at AWDisuzu house last friday he and Brad installed my Raptor shift light and they did a kick ass job looks like it came stock :rock: :rock: :rock:
and I saw both kits and Mike AWDisuzu ZEX kit looks very clean and SRTBrads kit does not have such a clean look and also had lot more to install:dontknow: :dontknow:
Cheers J.T.
what color of shift light did you get and where did you mount it? Im just not sure what nitrous system to get?
