MG42pillbox
What has to be done to these trucks to get 17s on them all the way around..
smaller breaks or what..?
FSTJACK said:Smaller brakes to get 17s all around.
The rear calipers can be ground /shaved to allow 17s to fit the rears but not the fronts.
Why. Ant nee?Venom Power said::dontknow: Jack, I'd still need to shave the rears on my '04 for 17" wheels?
fastestbrickonearth said:for weight reduction and less rotating mass
22's are worthless for drag radials.viperpwred said:ya but 17s would look REDICULOUSLY out of proportion on our trucks... id rather spend more money on a bigger lighter rim than smaller ones
Sportec Mono 10 weigh about 25/rim for 22"
Sorry guys I was mixing up the 16s and17s.FSTJACK said:Smaller brakes to get 17s all around.
505'sFastestViper. said:im gonna be running 15,s all the way around before lond
it will not be the factory setup at all wilwood rotors and calipers it will i promiseWOT said:Might work if you take the front calipers completely off, block off the front brake lines and then turn the front rotors down to about 14".
