Rick srt10
- Joined
- Nov 18, 2024
- Messages
- 4
- Reaction score
- 8
Truck just shuts of while driving or after you shut off won't start keep trying every 15 minutes after a few tries it starts what could be wrong with it
That's no good! I'm sure someone will have some helpful comments soonTruck just shuts of while driving or after you shut off won't start keep trying every 15 minutes after a few tries it starts what could be wrong with it
No codesStart by checking for codes .. turn key on , off , on off then on and leave it on .. look at the trip odometer and the codes will blink up .. that could help give you the answer ..
No codes never no when it's going to do itLike Jim said. First step is does it have any codes and if so what are they? Just by reading that I'd say check your grounds. Also, these trucks are know for harness damage on the passenger side right where the harness comes up by the manifold. Make sure its tied up and not touching!
No codesLike Jim said. First step is does it have any codes and if so what are they? Just by reading that I'd say check your grounds. Also, these trucks are know for harness damage on the passenger side right where the harness comes up by the manifold. Make sure its tied up and not touching!
@rottenronnie posted up on another thread pertaining to fuel fuel delivery system and pressure .. could be a possibility.No codes
