robwclark
Anyone who if the new style 8.4L Intake, throttle bodies, & valve covers will fit on our engines?
JMB Justin said:You have to swap the whole top end, heads, intake, etc. Also TB's are drive by wire.
Justin
robwclark said:Hmm. That would be straight pimp. I wonder how much trouble converting the TB would be? That sounds like the hardest part. But the heads will fit our blocks huh?
Eric said:In addition to the above, you will need a PCM to run the whole thing also, and all the drive by wire components for the gas pedal assembly inside the truck. Completely different animal as said above.
