2009 Hummer H2 - Direct TV Sat. System, Full Stereo System, Bone Stock other than that (excluding step bars and wheels
The "soon to be" Beast
The beginnings of a hotside...
A/W - Precision 1000 rwhp rated
A/W Mounted
Stock Manifold Flanges tigged to Stainless Piping
Another. Passenger Side Mount
t3/t4 Precision 54mm Turbo - Journal Bearing
Front View - No Ground Clearance Loss with Stock (and additional) skid plates
Turbos Mounted - Not Clocked
Another - Still not clocked
Drivers Side Mount
Heat Exchanger Mounted
Heate Exchanger Long View
Studded and Drain Flanges
Driver Side Turbo - Wastegate with Recirculation - 2.5" Downpipe
Passenger Side coming along
Drivers Side - Cold side/Hot Side
Front View/ Ground Clearance Shot - Twin 2.0" merging into 3.5" Aluminum to the 4" Inlet of a HUGE A/W intercooler
Underside with Cold Side including 2" cast 90* Elbow off the Passenger side Turbo
Wastegate Mounted
Passenger Side on the Bench - Recirculation Tube in the Works - Check out the tight radius cast elbow off the Compressor cover.
Almost complete Passenger Side
Turbosmart Wastegate - 38mm
Wastegate and Tig Welded Stainless
Recirculation Tube - Closeup - On the Bend for Minimal Turbulence
I thought it was pretty cool. All stainless hot side, all aluminum cold side. Should have instant spool with the cubic inch of the motor. Apparently they are running twin turbosmart 38mm wastegates and a single turbosmart 50mm raceport. Will be tuned with HP tuners when its ready.
Ill post up more pictures when they are available.
-Wade
A/W Mounted
Drivers Side Mount
Wastegate Mounted
-Wade
