25000 milesss
SRT10SECONDS
just turned 25k miles...anything i should do in the maintenance catagory for the truck...its and 05 qc
1) add FI.
2) Bulletproof engine
3) Bulletproof trans
In addition to standard checks (oil/filter, transmission fluid, etc.)
Inspect differential fluid.
Your spark plugs should still be good, but it couldn't hurt to check them.
Look for adverse wear on tires. (balance, alignment, rotation)
For these trucks, check your ground wires attached to frame, several trucks have had them come loose.
Any frayed wires. (O2 sensor wires, spark plug wires burned, etc.)
A few 04 RCs have had their crank bolt come loose. Haven't heard of THE 05'S OR 06'S having that issue however. Bigger bolt. 130 lbs is the torque required (Harmonic balancer pulley - big one at bottom)
Oh yeah, leaks in oil lines. Stinker has aftermarket steal braided lines. Same with power steering.
Do check the oil lines. Mine were leaking at 17k
Bigger bolt torque is 250 foot lbs, not 130.
