Rickspeed
Need a replacement Roe Injector 42# Delphi part number 01D030B. Thanks.
TNVIPER said:My understanding is the Roe comes with 48lb injectors (as his web site states)...the stock injectors are 42lb..........you might have the wrong ones...:dontknow:
When I got the kit, I called Sean to verify I got the right parts, and explained what the injectors looked like, and he said yeah, those are the ones with the blue collar on them. They are def not stock injectors. But that part number comes back as a 42# not 48#. I will be calling him on Monday to ask that same question.TNVIPER said:My understanding is the Roe comes with 48lb injectors (as his web site states)...the stock injectors are 42lb..........you might have the wrong ones...:dontknow:
Rickspeed said:When I got the kit, I called Sean to verify I got the right parts, and explained what the injectors looked like, and he said yeah, those are the ones with the blue collar on them. They are def not stock injectors. But that part number comes back as a 42# not 48#. I will be calling him on Monday to ask that same question.
TNVIPER said:My stock injectors have a blue coller too...compare the ones that came with the kit to the injectors you removed from your truck...if the same length something is wrong...
Rickspeed said:My stock injectors were skinny, and the ones I got with the kit are fat.
I will have to check when I get out of work tonight.TNVIPER said:Are they the same length?
