Anyone know if an old 727 torque flite trans has the same bell housing as our trucks? I'm thinking about ditching the 6 speed
Sissy
I believe you can use the bellhousing from the 12 valve Cummins' that had a 727. I think I remember reading the Cummins and our V10's share the same bellhousing.....
Dibs on you clutch/flywheel combo
I thought the basic architecture of our engines was based on the LA's? If so, wouldn't a small block 727 work?
Dude, in your own words. "the 6 speed is what really makes the truck cool"
i thought the 48re was just a glorified 727 with an OD... am i wrong?
I doubt a 727 will live long, even if it does fit. Would be an interesting experiment though...
why wouldn't you just use an adapter plate and a turbo 350 or 400 though?
I swapped from a 46re on my 96 ram to a 727. It made it into the high 10s then failed under a 250 shot. I then ended up swapping in a 502 6-71 blown and only found a 400th from raptor transmissions and gear vendor worked. Btw I have that entire motor and trans and gear vendors darn near new in the garage I'd you need anything. It took one run to find the frame was the weak point on the truck, something about 1050 hp with 900ftlbs of tq hitting the slicks with 2" 4 link. Once the bed didn't sit right the truck was tore down. But hey, I tend to over build everything.
I'd recommend going straight to the th400 or something like the 4L80 if you can.
If you don't go all out you might be sorry later.
