Ive had this car for a few years and ready for something newer now. Only open to extreme nice and clean running street cars/trucks with zero issues. NO Projects. My car has recently just been rebuilt
1993 WHITE/BLACK LEATHER COUPE W SALEEN KIT
331 STROKER R BLOCK W EAGLE 4340 0 BALANCE CRANK,4340 H-BEAM RODS,9:1 COMPRESSION CUSTOM DIAMOND PISTONS 800 MILES
CLEVITE H-RACED COTAED BEARINGS ANT HELL FIRE RINGS
TRICK FLOW FAST AS CAST 190 HEADS
COMETIC HEAD GASKETS
CANTON 7 QT OIL PAN
ATI BALANCER
TRICK FLOW R INTAKE
ANDERSON B 451 CAM
COMP GOLD 1.6 ROLLER ROCKERS
CV CUSTOM LENGTH PUSH RODS
ACCUFAB 70M THROTTLE BODY
POLISHED VORTECH T-TRIM WITH AFTERCOOLER 18LBS OF BOOST
FLUIDYNE RADIATOR
CUSTOM FAN WITH ADJ FAN CONTROLLER
70LB INJECTORS W 92MM MASS AIR
ANDERSON POWERPIPE
CUSTOM BUILT TWIN INTAKE FUEL PUMP SYSTEM [2-255LPH PUMPS] 8AN FEED 6AN RETURN
NEW AC SYSTEM
NEW T-56 MAGNUM 6 SPEED
QUICK TIME BELL HOUSING
MC CLOED TWIN DISC CLUTCH
STEEDA CLUTCH QUADRANT KIT
HPM CROSS MEMBER
CUSTOM LENGTH ALUMINUM DRIVE SHAFT
BBK 1 3/4 CERAMIC COATED LONG TUBE HEADERS
BBK HIGH FLOW CAT X-PIPE
MAGNA FLOW SS CATBACK
FLORIDA 5.0 GAUGE CLUSTER PHANTOM
PHANTOM BOOST GAUGE
PHANTOM FUEL PRESSURE GAUGE
BBK CASTERR CAMBER PLATES
TOKICO ALLUMINA 5 WAY ADJ STRUTS
KONI YELLOW 5 WAY ADJ SHOCKS
STEEDA SPORT SPRINGS
FORD RACING FRONT CONTROL ARMS
200 AMP ALTERNATOR
BILLET STEEL FLYWHEEL
T-56 MAGNUM 6 SPEED
MC CLOED TWIN DISC RST CLUTCH
SSR 18X9 18X10 W BFG G-FORCE KDW
KANEN 4 INCH COWL HOOD
FULL SALEEN KIT
New weather strip throughout
CUSTOM DYNO TUNE ON PUMP GAS 93 OCTANE BY PRO-DYNO
CUSTOM BUILT BY EXTREME MUSTANGS
APPROX 800 MILES ON ENGINE
A TRUE STREET CAR,HEAT,AC AND POWER!
OVER 60K spent in building this car. Price 23k,,, Call shop for details and proof of entire build
Extreme Mustangs CALL 704-400-1007
NO JOY RIDES!
CANTON 7 QT OIL PAN
ATI BALANCER
TRICK FLOW R INTAKE
ANDERSON B 451 CAM
FLUIDYNE RADIATOR
ANDERSON POWERPIPE
NEW AC SYSTEM
HPM CROSS MEMBER
PHANTOM BOOST GAUGE
200 AMP ALTERNATOR
T-56 MAGNUM 6 SPEED
FULL SALEEN KIT
NO JOY RIDES!
