A couple of handy calculators for builder/racers.
mopower1958
The corner of MOPAR LANE & DODGE AVENUE!
http://www.bid2race.com/DynamicCompressionRatioCalculator.php
This is a calculator to use when you change cams or pistons. It determines Dynamic compression which is the actual compression of an engine as it runs. If you change to a long duration camshaft it lowers the DCR. I used it on the Coronet engine to determine how much cam I needed to be able run pump gas with 11.5 static compression ratio.
http://4lo.com/calc/dynocalc.htm
This one is to determine horsepower by E.T. and MPH.
OK, so that means my truck must weigh 7720 lbs. 14.5 1/4 and we know the truck makes 500 HP means my truck weighs 7720. That's my story and I'm sticking to it. It's been mathematically proven.
mopower1958 said:
Try the MPH if you stayed in it on that pass.
It was my very first run ever in anything and I sucked. I know the truck has more in her. My second run I was spinning badly and my third run I did the dreaded 1-2-1 shift (B&M). I haven't made a run that I could make an accurate calculation with. But there's always next time.:D
