A LITTLE HELP WITH MY MIDS
tone
Member
Left Coast, Santa Clarita Valley
hey fellas, making an attempt to install my x metal mids and ran into a problem removing the old ones from the header side (the three bolts).....they have been sprayed with pb breaker, and i put my air gun to them and they still will not break loose.....any tips:dontknow: , i know this is the hardest part in removing these things....thanks guys.:)
Cut the bolts or find a long pipe to put over the ratchet handle to get the most leverage for breaking them loose.
You may be forced to cut them. If a long cheater bar doesn't do the trick it might just twist the nut off of them anyway negating the need to cut them. I've done it before...
Stretch
bolt lube penetrant...wait 5 minutes...unscrew em...
Also helps to have some type of man strength...j/k
I had to cut them off of mine also. Damn did they suck to remove.
Bill.
505'sFastestViper. said:
i bit mine off and chewed the metal
gives a new meaning to an iron stomach...or an ass made out of steel:D
please do not be hoing other threads up on topic or off limits bwhahahahahhaa
sorry, hopefully he got them off! I know they can be tough:)
