A V-10 for inside the house.
fursale
Knoxville TN
Must have for hopped up computer owners
Bigger is theoretically better when it comes to CPU coolers, as more metal means greater surface area to dissipate the heat generated by your processor. Cooler Master has taken that notion to the logical next step with the $139.99 V10. With three separate sets of aluminum fins, 10 heat pipes, and two 120mm fans, this monstrous cooler will chill more than just your processor. It can be mounted to sit over your RAM to keep your memory cool, too. Just make sure it’s compatible with your system. It supports all current CPU sockets, but at 9.3x5.1x6.3 inches, you’re going to need a lot of free space in your case. Cooler Master, www.coolermaster-usa.com:rock:
5_0_BAIT said:
I have something similar on my comp that I built awhile back it is bad ass and uses no fans (very quiet) Damn thing is huge!
Me too.Not as big as yours but
Cools a Q9650 OCed to 3.9 ghz.:)
Black1 said:
Damn!!! That's badass... does it just run off of heat convection? :confused:
It would if I was just running at 3.0 ghz,the stock frequency but at 3.9 I have a 120 mm fan pulling air through it.
