Thats guys so far for the help. This site is awesome! I appreciate everyones input!
Guess my main questions are (since I'm really new to this) is first (before the type of gauge) the types of gauges necessary, in example: the vac/boost gauge, with a standard pulley on the ROE, would the 30/30 gauge benefit me or should I go with the Ultra Lite Series that has the lower psi range? It may also sound silly, but do you also read the vac with a S/C?
The ETG is beneficial in what way? If you're only reading one cylinder, is it worth the effort in all the work to remove the headers for the install to read only one port and side only? (Remember, I'm new to this). How else do you identify if one cylinder is weak? Should I be looking for something else that will tell me this? With the above mods, and say the single port gauge is the way to go, what temp max are you looking for, the 1.6k or the 2k?
As for the solutions in install, reading and seeing other guys installs really help. Yes, I am going more for show than for the strip, but I would like to know opinions if I'm to make a choice!
Thanks guys! Still puzzled#%*^@@@
