aftermarket p/s lines
ctsrt10
Does anyone offer stainless steel power steering lines for our trucks/ i have to buy stinkers oil coolers cause mine are leaking and the warr does cover them also my p/s lines are leaking and they arnt covered so i want to replace with good ones any help?
When my high pressure line from my PS pump began to leak I researched and found an adaptor (Earls if I remember) that would screw into our PS pump and allow easy change over to AN lines. Being the cheap ass that I am I found an older Saginaw PS pump that had an inlet that had more material then ours that allowed me to weld on an AN fitting.
Regardless, all these quick connect fittings the manufactures are using to speed up assembly are garbage. I've been replacing mine with AN fittings as they begin to leak.
Not a great picture but you get the idea....This is coming out of the PS pump.
