Air Conditioning Inop
RAM82A1
North Georgia
Guys:
Went on vacation and before I did I thought I'd disable the old girl by pulling a couple of fuses. Got back and put the fuses back in and cranked her up. A/C doesn't work electrically and the speedometer and odometer are inop. The ABS and Brake light are also on. That led me to believe that I may have put the fuses back in the wrong locations, but according to the shop manual, they're ok. Could one of you guys with an '05 Regular Cab check the fuse box near the battery and let me know if fuses 3, 14, 30, 31, 37, 39 and 44 (and only those) are missing. With a flashlight you can read the number next to the fuse. I'd like to make sure I didn't screw something up before I suffer a trip to the dealer. Many thanks.
Pull the negative lead to the battery for an hour or so...then re-connect...that should re-boot the system and possibly correct the problems...
Disregard. I mis-read the manual and found one fuse in the wrong location. All is good again.
