air/fuel gauge
Is yours Narrow or Wide band? The narrow band A/F gauge bounces all over the place.
At $300 bucks. I'd think you'd have the Wide band. Did you install a wideband O2 sensor or did you hook it to one of the stock O2's?
No it came with everything. I think I might have mounted it too close too the EM. 5"... Where is yours?
I have the cheap narrow band A/F meter. It will run off the stock O2 sensor but the lights dance all over the place. The wide band requires it's own special wideband O2 sensor be mounted in the mid pipe somewhere. Some of the catless mid pipes come with an extra bung welded in just for this purpose.
Now Steve goin down the road it will bounce some , the computer is trying to acheive the perfect mixture of fuel and air, so the guage will fluctuate some, anwhere sometimes from 12 - 15 or so,
but under full throttle it should give a steady accurate reading, try that and see if it works, but under part throttle or idle it will move around bud.
had one on my hemi and under normal driving steady throttle will bounce lean to rich, under wide open throttle all the way rich then off the gas all the way lean.
Thanks guys . The next Time im at WOT Ill try and take my eyes off the road for a few seconds and hopefor the best!!:rock: :rock: ;)
