Aircraft Mechs are funny!
ntw0rk
Greenville, TX
It takes a college degree to fly a plane but only a high school diploma to fix one: a reassurance for those of us who fly routinely in their jobs.
After every flight, Qantas pilots fill out a form, called a "gripe sheet" which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics
P: Mouse in cockpit.
S: Cat installed.
And the best one for last.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
WILDMAN
I am an Aircraft Mechanic and I have seen some really stupid write-ups too. Some pilots are scary.
Wade
Hell, how many Aircraft Mechanics we got here??
I use to be a mechanic many moons ago at a little civil airport in Columbia SC. I was working towards my A&P but life got in the way. I worked mostly on Cessna's. 150, 172, 210, a 337 and a 421 I think. A Piper Apache and some Mooney's, a Beech Bonaza and a few other odds n' ends.
I used to do Avionics on Fighters
That's me. Air Force Ret. Crew Chief C141B Starlifter. Engine run, Refuel, tow, supervisor qualified. I have woke up the city of Charleston S.C. on a few occasions at 0200hrs. with a balls to the walls engine run. Nothing like 80K pounds of thrust under your palm.
Got me beat......
I was Run Qualified on F-16's, best I could muster was 35,000. But that was with one engine :D
But the after burner makes up for it. I love those rings. You should see a C-5 engine run. It's like a hurricain behind it. Lots of stories.
Sounds like the answers you get when you bring your rig to the dealership with problems.
worked nine years on the infamous U2 aircraft. Data link communications, EW, ELINT and SIGINT....that bout sums it up....
mh-47 chinook crewmember/mechanic here, thanks ntwOrk laughed my butt off from the wright ups.remember they trained a monkey to fly the space shuttle.push button get bannana
WILDMAN
I work mostly on King-Air 90, and 200's. But we do work on alot of others also. I am a fixed wing and rotorcraft pilot, Paramedic, journeyman Iron worker, I have a class A drivers license with doubles, triples, liquid tanks, Haz-Mat, and of course my A & P (Airframe and Powerplant). I have done alot of things in my 48 years. I don't know what I want to be when I grow up....
Wade
Damn, I could be an astronut.;) :p :D
Hell I'm an AM2 (AW) in the Navy work on the EP-3E and we have some retarded pilots. I would rather be dumb then a sissy and cry about every little discrepancy. Careful what you talk about were listening.
I was an AW2 on P-3C's, I have seen some of these write-ups in the VIDS/MAF books for sure!!
I thought it was funny, mostly because I can relate!!
Oh, I think one of my favorites of all time was a pilot that came back will fuel issues early.
Set the stage...
He was running intercepts of incoming aircraft.
Configuration: Air-to-Air, Training Aim-9, Training Aim-7, centerline tank.
Air Abort
Wing tanks will not feed
huh?
The funniest part of the whole thing, when he landed the crew dog pointed to the wing and told him no wing tanks installed..... Your Air-to-Air.
This guy blew the dream day. These guys would kill to be the Air-to-Air guy and not the Air-to-Mud.
BTW.....
The pilot could have just looked right and left and without much trouble noticed that no wing bags where installed......
Moron!
One other thing.......
It take balls to do what these guys do in combat
