Make the SE into an SRT.
Here is the option he should have gotten, and it is only a two day MOD !
Price: $5500 TOTAL Base Price
What you get:
Engine
Transmission
Engine Computer
Skim Module
Actual Igntion Key
Engine wiring
Underhood Wiring
Dash Wiring
Complete Body wiring
Instrumnet cluster
Axles
Shift Linkage
Shifter
Clutch, Brake, and Gas Pedal Assemblies
All clutch realted items(ie slave cylinder etc.)
All fuel System Evap Stuff and canister
All pipes (hot/coldside)
Intercooler
Complete Turbo assembly (never taken off the engine)
Intake manifold
Throttlebody
Power steering Pump
Ac Compressor
All A/c Lines
O2 Sensor Housing
Turbo Downpipe
Coolant Overflow Bottle
All fluids needed including oil, coolant, power steering fluid, transmission
fluid.
Any other parts required to complete the swap
Hotel reservation in town paid by us for the duration of your service.
Plus your choice of one of the following upgrades:
AEM Cold Air Intake
AGP Motor Mounts
Exhaust Depot Hardpipe Kit (requires purchase of aftermarket blowoff valve)
Crank Scraper
Prothane Suspension Bushing Kit
Optional Upgrades
- Complete Suspension swap/drop with Hotchkis Lowering Springs: $700
This gives you Monroe SensaTrac Struts with Hotchkis Lowering Springs. Includes 4wheel alignment.
- Complete Braking System Swap: $500
This changes your stock brakes over to the stock SRT braking system, regardless of if you have rear disc or rear drum.
- Complete Interior Swap: $700
This includes SRT Viper Seats, and Silver inner door handles
- Complete Brake swap with Front Big Brake Rotors: $1100
Same as Complete Braking System Swap, but also included is the Wilwood Front Big Brake Kit, your choice of red or black calipers, smooth or drilled/slotted rotors.
- Mopar State 2 Turbo Upgrade with Toys: $1600
Includes Stage 2 Computer, Stage 2 Wastegate Actuator, 3.0 Bar Map and Tip Sensors, Stage 2 Fuel Injectors. Toys includes Intercooler Sprayer, High-Octane Mode Switch, Dial-a-Boost Boost Controller
