mopar_mudder
Put in my B&M shifter finally. First thing is that the rubber boot the bolts down to the floor doesn't fit well over the top of the B&M's higher base. The right rear corner of the boot wont go tight to the floor, I may pull it back apart and do some modifing. Also the bolts that bolt the shift lever on, had to grind them off to try and keep them from punching through the side of the leather top boot.
I mounted the lever at the lowest setting, it sits a little below the level of the councel when it is down, but it is still fine to drive with the councel down.
the stock lever had a through of 5.5" from front to back (3rd to 4th). the B&M in the lowest setting is 3.5", so that is a 2" gain, not bad.
The drive, I didn't do much, just a quick run to the store. You can hear the difference in the noise when you start it up, but it is not terriable, I can live with it. The 1-2 shift is very nice and close, quick. 3rd is not bad, still a little notchy feeling like you have to "wait" for it to fall in. That is kinda what I expected, it is the design of the trans and no shifter is going to fix that. Personaly I never had a problem with the stock shifter so I not seeing any huge improvent other then the shifts are closer which can speed things up. As far as driving it does take more effort to drive because of the stronger centering springs and the fact that you have less leverage for the shifts. So I guess I like it but I am not blown away by it either.
