Another engine code question- PO153?
BIG NANA
Jacksonville
Help Me please what is this? according to web it means " O2 Sensor Circuit Slow Response (Bank 2 Sensor 1) " What the hell does that mean? I assume it has something to do with my o2 sensor on the passenger side after i put the JDM catless mid pipes in, but not sure, anybody have some input?
What did you do with your second set of sensors if you went catless? If you let your wires hanging or the sensors hanging under the truck I think we found the problem.
You need rear sims. Boomer also has another cheaper solution from what I understand, but I did mine before that so I am not sure what it entails.
check your front passanger-side 02 sensor for line breaks, not correctly seated in the plug....or might just be bad (autozone)
-Red
Hmm, I guess that is right, 1 would be upstream, hell with the rears if it is not saying 2 :D
If I recall those wires on the front O2s went off into never never land when I did my exhaust. So when removing them and putting them back in you do twist up the wires a little, well unless you trace those wires and unplug the other end. So, yea, the loose wire could be a very big possibilty.
