I have read many posts about the slave shims with the master/slave kits.....all mention that the slave shim is a must....is this just a 04/05 model thing?...my dealer installed mine and the tech did not use the shim for the slave...I also installed the Centerforce clutch....truck now shifts great...better than ever....am I doomed to future problems?...
...I have had a whine show up a couple days ago...trans whines when I give a little gas under load especially in 6th gear....dealer thinks maybe a bad imput shaft bearing...and ideas here?..:dontknow:
