Any detailed threads about removing dash ?
Discussion in 'General Discussion' started by 2quik6, Aug 5, 2022.
Car Parts
  1. 2quik6
    2quik6 Full Access Member
    62
    36
    Jul 19, 2017
    Are there any detailed threads about removing the dash in a 2005? Need to replace AC evaporator, need help for around the steering column area on what to unbolt. Found a youtube vid for a 2006, regular Ram, but the SRT seems to be very different under the steering column.
  2. 2quik6
    62
    36
    Jul 19, 2017
    Got the info I needed from the FB group! There are 4 bolts holding the steering column in, then 2 right next to the front steering bolts that hold the dash on to the support structure mounted to the firewall. Just undo the 4 for the steering column, and the 2 for the dash...support structure bolted to firewall stays in place.
  3. AMS3
    AMS3 Well-Known Member
    996
    646
    Aug 8, 2019
    Savannah Ga
    Quick question. Once you removed the dash, does it give you access to remove the cluster glass? Somehow, a previous owner got some type of liquid on the inside of the glass, and I have no way to remove and clean it.
  4. HemiLonestar
    HemiLonestar Member Staff Member Super Moderator
    53
    41
    Dec 31, 2009
    MD
    No, just pull the cluster by itself, then remove the plastic lens (like 4 screws holding it on).
    Bad Azp Performance and AMS3 like this.
  5. AMS3
    996
    646
    Aug 8, 2019
    Savannah Ga
    Thank you!
  6. Bad Azp Performance
    Bad Azp Performance Member
    55
    42
    Nov 9, 2021
    Las Vegas Nevada
    Its a little easir to get out after you remove the bezel from the cluster to the radio.
    Towel on 4way button as you tilt it out.
    The lens for the cluster is actually a seperate piece
