Last night we had a towel ring fall off a bathroom wall. After I removed what was left of the ring's support bracket and the mold infested drywall I discovered the previous owner of my North 40 either failed or neglected to use a stud/pipe finder before he drilled into the drywall. Yep, he drilled three holes into a 3" schedule 40 IPC PVC waste line that services a second floor bathroom. Two of the holes are dead center in the pipe. The third is slightly to the right of one of the holes. I guess he "missed his mark" trying to hand the friggin' towel ring :dontknow:
My question is can I use PVC dowel rods sized slightly larger than the holes to plug them? I plan to use PVC glue and the purple primer to hold the plugs in place. The hole diameter is approximately 3/16".
