kickinassrt-10
has anyone dared to put, or accidentally put any gas with octane less than 93 in their truck? what are the affects if any to the engine?
I never knew that, but it makes a ton of sense. Since the oxygen is so much thinner at elevation. Less air means less fuel/air mix. You learn something new everyday.alexspop said:The higher the elevation where you live the lower the octane rating needed. When I lived in CO 89 was the highest we could get.
spdrcrj said:I'm have a custom tune for 93 gas but the best here in Vegas is 91 at 3000 ft and will only have 90 available in Clovis, NM at 4200ft. I should ask Sean but about the altitude but what is your guys experience. Should I run the 93 tune or Sean's mid or low tune?
tia,
Jim
kickinassrt-10 said:I live in Florida so it's either 89 or 93...I think I'll just stay with high test.
TNVIPER said:Higher octane gas actually has less BTUs (energy measure) per gallon than low octane....if the motor is not designed to run on high octane you are actually loosing some power....our trucks are designed to run 91 from the factory.......I would not use any less than 91 no matter how well it runs....detonation can be hard to hear sometimes...
WOT said:That used to be true, but not so much anymore. It more so depends on the gasoline and the crude it is refined from. Some 93 has more BTUs/gallon than 91. Varco Products makes racing fuel at high octane that has more BTUs/gallon than pump gas.
The reason you used to lose power from running 93 octane on an old, low-compression motor from the 70's that was designed to run on 87 was more from the slower burning rate of the high octane fuels of that era than from the BTU content. Now days, the high octane and most of the racing fuels typically are formulated to maintain a faster burn rate so that they do not incurr a power penalty on lower compression motors.
Plus, modern wedge shaped combustion chambers promote fast burn rates on all types of fuels and have greatly increased the power output of motors on both low and high octane fuels..
