b&m bolts
Ironhead
h-town
anyone ever break the bolts on thier B&M shifter??i broke mine this afternoon ,,well one of them the top one sheared off ,,i had to shift truck by grabbing bottom of the shifter to get home :mad: im thinking on getting new bolts and welding :(
Just get some grade 10 or so :D :D :D :rock: :marchmellow: :marchmellow: :marchmellow:
They should not have broken unless they were working loose. Like Denise said put in some grade 10 and tighten them periodically.
WOW,:rock: I made a tec post backed up by an expert :D I did, I did:D :D :marchmellow:
are you two done stroking each others ego now lol:D
my shifter broke at the top where the ball was at i just rethreaded it and screwd the ball back on!
When I had my B&M I stripped a bolt, and I got a replacement from a local bolt and fastner store. I would bring one to the store as a sample to make sure that you find the exact match. Should didn't be to difficult to find.
"Should didn't be to difficult to find."quote
Ya what he said ,i think
I am finding the studs that come with the shifters are breaking alot. just put the B&M shifter in my Cobra last week and today as I was putting in the new clutch the studs in the shifter were sheared off when I went to loosen them.
All hardened bolts are not created the same. Grade 5 has 3 marks grade 8 has 6 marks , go fiqure:confused: Grade 10 bolts will not shear off unless you have an arms like Lbstone:D :D :p :rock: :marchmellow:
Wifey said:
All hardened bolts are not created the same. Grade 5 has 3 marks grade 5 has 7 marks , go fiqure:confused: Grade 10 bolts will not shear off unless you have an arms like Lbstone:D :D :p :rock: :marchmellow:
well i would have to admit im not the smallest boy on the block :)
i replaced them with some stanless ones ,,thats all the hardware store near me had on a saturday ,,when i get to shop on monday i will see if we have some metric countersunk cap screws we use on tooling dies ,they are hardend to a high rockwell hardness ,,way better than 10,,i guess next i will snap off knob :embarassed:
Right on:D :D Stainless will never attain the shear/ tensile strenght of a good carbon steel , particularly in the 300 series alloys, to much nickle (soft) and to much chromium (brittle) in the other SS alloys.:argh: :argh:
moparracing said:
your percentages are alittle low...... :D
.0059894585529468136080498322951605%
Getting better:p 0059894585529468136080498322951606%:D :p
