Battery relocate Kit (NEED PHOTOS)
OSO said:
I'm moving the fuse panel inside and wanted to move the abs controller to the fire wall. Guess i can always try it and see if it still stops:)
I dont see why it wouldnt work. Let me know how it works out. Wheres the fuse panel going to go? Behind the glove box?
Driver side under dash should have pics tomorrow.
My earlier post didnt sound how I wanted it to. I mounted the ABS under the truck on the frame rail, with the controller level (as it was in the original location) and the lines pointing forward. I think it will turn out nice when its done as you cannot see it from any angle. I used part of the battery box that holds the controller and attached it to a metal bracket to make the mounting simpler. Then I could still use the rubber isolators for the controller.
Sounds better:)
Got board :)
we can get stinker in on it and have a three way race...lol he's in the same boat.
Spaghetti!!
Continuing my battery and fuse box relocation.Oh when i was moving my abs controller i heard a rattle decided i wanted to know what made the noise. What do you see? Its out of focus but you should be able to tell whats out of place
The battery relocation kits out there didn't look like mine:D
First 21 wires extended.
Well theres your problem!!
Long way to go
Long way to go
:eek: :eek: Damn dude...that's going to be alot of work. Should look killer when your done.
wonder how many of them wires ya could do with out??????
Definatly going to take some time since its cold and raining and there is more to that rats nest on the inside. Plan is for the only esposed wire to be on the motor ?(injectors coils and sensors. The rest of the wire will be ran in the frame if it needs to go up front.
There are 30+ wires that i will be removing a 2+ foot section from. A nother 60 or so that i will remove a 1' section from. There are a few wires from the electric brake connection i will be removing completely.
sounds like fun.:rock: :rock: :rock: :congrats: :congrats: :congrats:
Got a bit more done need to extend a few more wires and build the bracket for the abs controller. Tacked in a patch for main harness hole need to put a coat of paint on it next.
