phxpoolguy
Anybody have a problem with a bent leaf spring? Trucks sitting higher on one side and it didn't launch the same at Pinks on Saturday.
JTS VENOM PERFORMANCE said:if you have the rear lowered and no caltracs yessir it is possible, I have a set of warped ones on my personal truck
VENOMOUS1 said:Get under her whilst she sits on the ground or ramps and loosen spring bolts and shackle bolts, jump up and down a few times and retighten. I have had springs buckle from sticky launches and get the shackle in a bind. Willing to bet it works!
Springs are just that, spring steel and they have memory. They will always want to return to their formed state so re arching and de-arching rarely lasts. Also another reason I say the shackles are bound and springs just stuck in that position until freed.
phxpoolguy said:Thanks, I'll try that first while I find a set of RC springs, I hear they're supposed to be stronger. Goes to show how well those Nostalgia slicks hook up ( 1.60 60ft.).
VENOMOUS1 said:Yep, you wrapped the springs on launch and the shackles are bound up, I bet!
Nothing wrong with the springs more than likely. I personally think the slapper bar does help a lil with this from the factory, but a four link, or simple ladder bar setup should alleviate this issue. 1.60 60' is awesome in a QC bro. I take it you have a stall and spraying off the line?:tee:
