Best or recommended Sealant for Valve Cover Gaskets
Discussion in 'General Discussion' started by Raiiin, Oct 31, 2019.
Car Parts
  1. Raiiin
    Raiiin Member
    37
    11
    Oct 2, 2019
    I've currently got the top of my motor apart and I know people use a lot of diffrent sealants. I personally use Indian head glue usually, but I was just wondering if dodge has something they recommend and what every ones personal opinion on what the best is?
    Also, do anyone know the torque specs to the valve cover bolts?
    Thanks to everyone that has helped me out in the past my truck has came a super long way since purchasing it in plan on posting before and after pictures of the truck and the bay after I assemble the truck back together
  2. CaptnCrash
    CaptnCrash Full Access Member
    217
    38
    Jul 1, 2014
    The valve covers are O ringed, no sealant is used. Just make sure everything is hospital clean and you can lube them with some light oil if you like.
    The FSM specifies 95 INCH/lbs using a criss-cross pattern to tighten ...
    If you use a bolt made from stainless make double sure you use anti-seize.
    THEWELSHM likes this.
  3. Raiiin
    Raiiin Member
    37
    11
    Oct 2, 2019
  4. CaptnCrash
    217
    38
    Jul 1, 2014
    If in doubt, use the anti-seize anyway, it can't hurt.
