Ponchopwr70
- Joined
- Apr 27, 2015
- Messages
- 133
- Reaction score
- 4
Looks like my ram will be getting the upgrade hydraulics. I bought this truck with 17k just hit 23k and figured I would flush the brakes and clutch. Well when I cracked open the bleeder no fluid came out so I hooked up my mighty vac gave a few pumps and still nothing, gave it a few more and a bunch of white paste came out (I could see it in my clear tube.) So I keep refilling the master and sucking fluid out. When I was done, went and hit the pedal, went to the floor 3 times. I figured I had air in the system, nope, I saw all the fluid pouring out from between the bellhousing. I can't believe that happened. This is not my first time dealing with a system like this, I run a Howe t.o bearing with wilwood master in my lemans never had a problem bleeding that one. So I'm heavily leaning towards the jtsvp kit cheaper than the roe but I can't tell if it has the factory pedal switch. Anyone have any input on this?
