Stinker said:I gotem bro, make you akiller deal , no worries jsu let me know![]()
Thanks Tony. I'm not positive what I want to do yet, as I need to get through this month. So I will just check with you next month I decide to go that route.
Smoke
FlyingLow said:You bring up one of my next mods. I have talked to great extent with Roe Racing and with STS. For a while I was tradding emails daily with Rick Squire. But to answer your question Roe advised me to get the VEC2 (now it would be VEC3) and bigger injectors. Then the VEC3 would control all the injectors (both engine and turbo). I'm not sure as to the size of the stock injectors, but I know you can upgrade to 42 pound injectors. So the stock ones must be below 42.
Stinker said:Stock injector are around 32lbs.
I have a set of 60's if anyone is interested, and no they arent too big, you are only using a percentage of the injector
TurboFreak said:If you get the VEC2/3 with larger injectors then you would not need aux injectors, right?
