Bought an OBD2 to usb connetor
bigike
Katy (BY GOD) TEXAS!
http://www.amazon.com/Crescent-OBD2...ostic-Scanner/dp/B001MT0XPK/ref=pd_sbs_auto_2
I bought this for a program I aquired called pcmscan. It's a data logger that I found out about on the vca forums. I thought it would be good for me to log and send to sean and figure out whats wrong with my tune. It also has a dyno , diagnostics and all sorts of other jazz.
http://www.palmerperformance.com/products/pcmscan/index.php
If any of you want to know more about it email me and i can hook you up. but you will need the obd2 to usb adapter.
How do I data log with the vec? do i need to buy the program from sean?
from what i read this pcmscan is more in depth???
66 bucks.
I wrote Sean a email asking if this would be suffice to data log and tune with.
I have a feeling that it will not tell me anything that the vec is doing, except the afr. As the pcm sends its signal and the vec recalibrates that signal.
I may still have to get the vec software and data log with that.
But this should be fun to play with in the truck and magnum!
It prints you out a time slip!
