Braided Nos lines
And what failed?
Oh and what failed was I spun 2 rod bearings on the side of the motor I was pulling fuel from and melted the 1st 2 sparkplugs on the pasanger side. So I beleive pulling fuel from the fuel rail caused all my problems.
Also if you are not running a direct port, with our intakes being so long it is like 1st come 1st serve when it goes in,
spray said:
And what failed?
Well I can see how you lean strongly on your theory. Actually with that said After this run Next time i shoot I will go with dedicated fuel supply. Thanks for sharing your experience.
BTW how big of a shot did you go?
I also have the cold fusion dual nozzle viper kit. the solenoids look like they flow pretty good
Also, what bank did you mount your wideband on to monitor?
With the case you just mentioned I will be mounting it on the pass side since i will be drawing fuel from that side of the rail
