Brake pad swap
mosrt10
St Louis, Mo
Let me tell you folks 3 wheels on my brake change went smoothly, oh yeah that leaves the rights front wheel. Let me tell you that one is a real as@#&le. I have tried everything. I'd like to find the fella that put them on with the impact wrench on the assembly line in Mexico. I tried a breaker bar, heat, brute force. I actually decided to stop before something or someone got hurt. But on a brighter note I have never seen such easy pad removal(once I called Justin:D). thanks again J
damn.. i didn't have that problem at all :dontknow: then again.. i did take
my calipers off to do work on then :rofl: :rock:
you try some PB blaster or anything to try and give the bolt some lube?
Sharpi
yep, sure did. soaked it while I worked on the other brakes. Today we go pneumatic on it.:D
