Brake problem...
Sammy11
Belgium
since last week i noticed that my light from the handbreak is on.
and when i start again it goes off...
it goes on when driving and sometimes when i stand still...
handbrake is not on , brakefluid is full , ....what else ?
i dont feel any brake problems.
DIABLO_X22 said:
Pushdown On The Handle, See If It Goes Out, Cable
Might Need Adjusting.
i never use the hand/foot-brake.
would be odd that the cable must be fixed...:confused:
i did the test but nothing...
GADodgetech said:
Fluid level sensor is most likely bad.
can i check that myself ?
sorry , i'm not that technical...:) :eek:
might just unplug the harness at the sensor & see if any corrosion is visible.
then plug it back in & see if that helps
i've seen quite a few of those go bad, there not expensive, so just go ahead and pick another one up :rock:
if you need install instructions... .pm me
i had that problem.. put the brake on in park, then take it off usualy helped me, dealer couldnt find nething wrong and it kinda resolved itself.
switch may be sticking... i applied mine hard and then popped it (released) with the handle a couple of times.
same thing happened to my truck when i changed the battery i noticed it was gone.
