Brake rotor question???
SRT-QC
Sarasota Florida
My buddy has a mobile mechanic service and we tried to turn one of the front rotors yesterday before installing new pads.Well his lath is not big enough to start with and then it just chewed up the rotor.
I called everywhere and it seems that nobody other than Dodge dealerships can get a new rotor at a cost of $239 WTF????
Does anyone know of any other place to get rotors for this overpriced nightmare I got myself into?
Thanx,and please understand that I have been very upset at the cost drop after I paid $54,000 last year and then the tires are outrageous and now this brake crap!!!I like my truck but god dang rite now its just an over rated pile of metal with no balls.It sux that I have to dump another $1,500 into a exhaust and computer just to get it to be the truck I thought it would be to start with.Man I hope this rotor crap isnt going to be an every 20,000 mile replacement.:mad:
I understand your pain. But I think rotors are pricey. Contact Dragon who is a vendor on this site. He works at a dealer and might be able to help you out.
I can understand the frustration however I think you need to look in the mirror before placing blame on your overrated pile of metal with no balls. New vehicles are NOT investments. You were awake when you test drove it then signed on the dotted line right? Did you stop by the parts counter to inquire upkeep costs for high wear items like tires and brakes? I'd be looking at your mobile mech to make right with the rotors. A couple minutes with a micrometer would tell you if you could turn them with favorable results. Fact that his equipment f'd them up beyond the min limits is his fault not yours nor the manufactures.
Sorry if I sound direct but have had to endure listening to a bunch of whinny democrats complain how bad life is....its all GW fault. :fight: You're not a democrat are you :eek:
Chuck I did test drive this truck when I purchased it new but I drove it with caution due to the 6 miles it had on it.I wanted to break the motor in so no I didnt hammer down the first day.Oh didnt I mention that the dealership had the truck back the next monday after buying it on a friday afternoon at 5:00 and ten miels down the road the truck kept dying at everystop light and wouldnt idle over 500 rpms.The truck didnt get fixed for two weeks.I bought a brand new truck and it sat at their shop while I sat depressed as hell.Its fixed now seemed it was an idle speed motor in the throttle body or something like that.Another thing is that I would never think of a truck as an investment.However I wasnt told that 6 months later I would be able to buy the same truck for over $15,000 less:dontknow: .I have had Ron do my brakes and all my vehicle work for many years.It wasnt his fault.He had a brand new cutting tooth or whatever its called but its like the metal is too hard or something.
The point here is too vent a little about the truck afterall I switched from a Lightning and then a Harley S/C for this and I am not at all impressed but most importantly to find out where to get a cheaper rotor than the dealerships $239 price.I am married to this F@#KING thing now.I just want to geta rotor:p
How many miles on your ride SRT-QC? I will say that for a stock QC 13.5 is a great time!!!
EBC makes aftermarket rotors. PerfectBrakes.Com shows a slotted/dimpled EBC set for $198.
They have an OEM set which assumably sells for less but you have to email for the price.
http://www.perfectbrakes.com/products.asp?cat=1252
Also AutoPartsWarehouse.Com has the same EBC slotted/dimpled rotors for about $20 less (and also a PowerStop Cross-drilled brand - same price per pair):
EBC: http://www.autopartswarehouse.com/p...7&modelid=82&year=2005&partid=78&brandid=2162
PowerStop: http://www.autopartswarehouse.com/p...7&modelid=82&year=2005&partid=78&brandid=2234
My pile of metal has plenty of balls. You must have got a dud. ;)
I know you were just venting....
DOT: Ya just venting.Thanx for the leads.I keep reading off and on about those brakes actualy fitting.I need rotors by monday at the latest.I cant drive the truck right now with the chatter.I got my freinds cost at the dealer at $180 something a few minutes ago.I'm just going to get them there and be done with it.It sucks this had to happen on a thursday befor the weekend I had planned to take the Baja 23 out on the bay.
Flyin low:Ya its only in cold dry air though.14.20 ona normal summer day.After the flash,exhaust and K/N filter I hoe to get high 12's in the winter air down here in Florida.
i have a set of the EBC Rear Rotors I picked up for 170 new from speedy performance. I have not installed them yet so I'm not completely sure they'll fit!
I also have new brake pads for front and rear. On the fronts....do I need to do anything to the rotor before installing the new pads? I don't know what turning a rotor means. Do they need to be resurfaced or just put in the new pads?
Generaly people have the rotors turned or resurfaced.It meens they get put on a Lathe that turns the rotor while a cutting tooth ot chisle cuts a small depth and reveals a new metal surface.Usualy if you let the breaks wear too much is when they need turned.
Something I saved a while back....
Brake rotor refinishing might not be a very good topic for the Jerry Springer Show, but it sure generates a lot of arguments. Consider the following:
* Rotor surface finish: How smooth is smooth enough? Says who?
* Rotor resurfacing: Should rotors be turned every time pads are replaced or not?
* Rotor runout: How much is too much? How do you compensate for it or get rid of it?
* Rotor flatness and parallelism: How much is too much? Can you even measure it?
* Rotor thickness: How thin is too thin?
* Hard spots: Will resurfacing remove them or will they come back?
* Sanding rotors: Does it help? If so, how should it be done?
* Resurfacing equipment: A bench lathe, an on-car lathe or both?
* New rotors: Install as is or resurface to true up?
Opinions differ about most of these topics, and in some instances opposite points of view may be equally valid. If you've been refinishing rotors a certain way and have not had any problems, great. Stick with it. Don't fix it if it isn't broken. On the other hand, if you've had a lot of problems such as brake pedal pulsation, hard pedal or pulling, or noise, perhaps you need to reassess your approach to rotor refinishing.
Regardless of your views on these issues, the objective in every case is to end up with brakes that stop smoothly, quietly and safely. Do it right the first time and you won't have to redo the brakes again later.
ROTOR FINISH
How smooth is smooth enough? Smooth enough not to cause pad chatter, noise and increased pedal effort. Turning a rotor too quickly on a lathe leaves grooves in the surface. The grooves are not parallel, but spiral inward towards the center because the lathe bits cut from the outside of the rotor toward the center. When these grooves make contact with the pads, they tend to grab and jerk the pads up and down, setting up vibrations that cause noise and may be felt through the pedal.
If you can feel the grooves with your fingernail, the rotor is probably too rough. Another test is to write your name on the rotor with a ball joint pen. If the ink breaks up into dots instead of a continuous line, the rotor is too rough. Smoother is always better because it affects the coefficient of friction, noise, pad seating, pad break-in and wear.
Too rough a finish on the rotors can also increase pedal effort because only the peaks between the grooves make direct contact with the pads (at least initially). As the brakes are used, the pads will eventually wear down the peaks and increase the area of contact. But this accelerates both rotor wear and pad wear. So again, smoother is better.
As a rule, most new OEM and quality aftermarket rotors have a finish somewhere between 30 and 60 microinches RA (roughness average) with many falling in the 40 to 50 RA range. Some say a rotor finish of 80 microinches or less is good enough for most vehicles. Others say 60 microinches is the magic number, or 50 microinches or less if the vehicle is especially sensitive to rotor finish.
The finish is affected most by the crossfeed rate of the lathe, and to a lesser extent by the depth of the cut. Most experts say the best finish is achieved by taking off the least amount of metal as possible. Not only does this extend rotor life, but it also reduces the amount of folded and torn metal on the surface of the rotor.
As a rule, the depth of a finish cut should be .002 to .008 inch. If the rotor is in bad shape, multiple cuts should be used: one or more rough cuts followed by a shallow final cut.
On bench lathes, a spindle speed of 100 to 150 rpm with a crossfeed rate of .002 inch to .005 inch per revolution should produce a smooth, high-quality rotor finish.
On bench lathes with adjustable spindle speeds, the spindle speed should be slowed down for larger rotors. One manufacturer suggests the following speeds: for 10-inch and smaller rotors, use 170 rpm; for 11- to 16-inch rotors, use 100 rpm; for 17-inch or larger rotors, use 60 rpm.
The type of tool bits used in a brake lathe also affect the surface finish. Round carbide bits generally produce a smoother finish than angular bits and allow a faster crossfeed rate to save time. Titanium bits with parallel, peripheral ground edges are considered premium bits for this type of work.
When turning composite rotors, be sure to support the rotor properly with large bell clamps or adapters to prevent flexing and chatter.
EVERY TIME OR AS NEEDED?
Should rotors be turned every time the pads are replaced? Many shops resurface rotors every time the pads are replaced whether they really need it or not. Why? Because they want to avoid comebacks. Besides, many customers might think they are not getting their money's worth if the rotors are not resurfaced as part of a brake job.
General Motors has a different opinion. In technical bulletin #00-05-22-002 to its dealers, GM says, "Brake rotors should only be turned when one of the following rotor surface conditions exist: severe scoring with depth in excess of 1.5 mm or 0.060 inch, pulsation from excessive lateral runout of more than .080 mm or .003 inch, thickness variation in excess of 0.025 mm or 0.001 inch, or excessive corrosion on rotor braking surfaces."
GM also says "Rotors are not to be resurfaced in an attempt to correct the following conditions: noise/squeal, cosmetic corrosion, routine pad replacement or discoloration/hard spots."
In other words, GM frowns on rotor resurfacing during what it calls "normal" pad replacement. But is any brake job ever normal? Every job is different and every rotor needs to be carefully inspected and evaluated to determine its condition when brake work is done.
GM says resurfacing rotors unnecessarily shortens rotor life. They also say resurfacing is "ineffective at correcting brake squeal and/or premature lining wear and should not be used to address these conditions, unless specifically directed to do so in a service bulletin." Yet, how many service bulletins have we seen over the years from GM and other auto makers who say the fix for a particular brake squeal condition on a certain make or model is to replace the pads and resurface the rotors? It can be rather confusing.
RUNOUT
Though you may not take the time to check it, many experts say you should always measure rotor runout before the rotors are removed for resurfacing. Why? Because if there is runout in the hub, it will make the rotor wobble as it spins. This, in turn, can lead to uneven wear and pedal pulsation.
Rotor runout can be caused by several things: variations in manufacturing tolerances, sloppy resurfacing procedures, a buildup of rust and corrosion between the rotor and hub, and uneven torque on the lug nuts.
As a rule, rotor runout should be less than .003 inch on most vehicles. Aiming for .002 inch or less runout is even better.
On 1997-2002 Chevrolet Malibu, 1997-1999 Olds Cutlass, 1999-2002 Olds Alero and 1999-2002 Pontiac Grand Am, GM says .0015 inch or less of lateral runout is needed on the rotors to prevent pedal pulsation.
If runout is excessive, try indexing the rotor on the hub to see if a change in position helps.
Once you know how much runout is on the vehicle, you can compensate when you cut the rotor on a bench lathe. Mount a dial indicator on the knuckle or caliper support and measure rotor runout. Note the location, amount and direction of the runout. After mounting the rotor on the lathe, check runout again with a dial indicator. If it isn't within .003 inch (and at the same location and direction) of what it was on the vehicle, adjust or shim the rotor mounting until the runout is duplicated.
Thin, tapered steel shims are also available for some vehicles to correct runout. The shim is installed behind the rotor with the thickest part 180 degrees opposite of maximum rotor runout.
The other alternative is to eliminate the runout using an on-car lathe to cut the rotors in place.
ON-CAR VERSUS OFF-CAR RESURFACING
When used properly, both types of lathes can give you good results. However, unless you compensate for rotor runout on the vehicle when using a bench lathe, you can't guarantee a true running rotor when it goes back on the hub. That is one of the advantages of on-car lathes. They cut the rotor true to the direction of rotation and virtually eliminate runout problems. The drawback with some on-car lathes is they are expensive and require a certain amount of skill to setup (equipment with automatic compensation simplifies setup considerably).
On-car resurfacing is approved by most vehicle manufacturers, and is recommended for any vehicle that is sensitive to rotor runout. It can also save a lot of labor on cars that have hard-to-remove captured rotors (certain Japanese makes) and on rear disc brakes.
If a rotor is cut on a bench lathe without taking into account runout on the vehicle, it can create rotor wobble that will lead to pedal vibration and uneven rotor wear. Even if there is little or no runout on the vehicle, mismounting the rotor on the lathe can create runout as the rotor is cut.
Causes of this kind of runout include worn arbor hardware, not centering the rotor properly on the arbor, dirt or dings on the rotor hat or center opening that prevent it from mounting perpendicular to the arbor, or misalignment in the lathe itself. The key here is to inspect your lathe regularly with a dial indicator for runout, and to make sure the rotor is mounted as straight as possible when it is cut.
FLATNESS & PARALLELISM
Opinions differ as to how much variation is OK in flatness and parallelism between the rotor faces. Some say as little as .0003 inch variation can cause a noticeable pedal pulsation on some vehicles.
The bottom line here is if the driver can't feel a pedal pulsation, the rotors are probably OK. But if there is a pulsation, you can usually assume the rotor is warped or has variations in thickness and needs to be resurfaced or replaced.
Measuring flatness and parallelism is difficult (some say impossible) because it requires numerous measurements all the way around the rotor (eight to 12 places at least). If the tip of the micrometer happens to line up with a small pit in the surface, it will give a false reading that may lead you to think the rotor is warped when in fact is isn't. Most technicians don't have the time to take all of these measurements, so they just turn the rotors, cross their fingers and hope the rotors are true. Usually they are.
ROTOR THICKNESS
Yes, thickness matters. Rotors must have enough meat to absorb and dissipate heat, and to maintain their structural integrity. Thin rotors are dangerous rotors that increase the risk of heat fade, cracking and failure. That is why most rotors have a "discard thickness" or "minimum machine to" specification on the casting. If you can't find it or the numbers are illegible, look up the spec in a service manual or electronic database.
The "machine to" spec includes a built-in safety margin of .03 to .06 inch. to allow for wear when the rotor is returned to service. But on Fords there is no "discard" dimension, only a "machine to" spec. Ford says their "machine to" spec leaves enough margin for safety so the rotor should last as long as the pads. However, if a Ford rotor is worn below the "machine to" thickness, it should not be resurfaced or returned to service. It must be replaced.
Rotor thickness should always be measured with a micrometer when linings are replaced, before rotors are turned, and after rotors have been turned to make sure the rotors are within specifications. There should be no argument on this point!
HARD SPOTS & CRACKS
Hard spots in rotors lead to uneven wear and changes in thickness that cause pedal pulsation. Hard spots may be the result of poor quality castings or from excessive heat that causes changes in the metallurgy of the rotors. A sticky caliper or dragging brake may make the rotor run hot and increase the risk of hard spots forming. Hard pots can often be seen as discolored patches on the face of the rotor.
Resurfacing will shave the tops off the hard spots and restore flatness and parallelism, but it is only a temporary fix. Sooner or later the hard spots usually return and you have he same problem all over again. A better repair option here would be to replace the rotor. Cracks are another concern with rotors. Cracks can form as a result of poor metallurgy in the rotor (too hard and too brittle because the rotor was allowed to cool too quickly during the casting process). More often, they are the result of excessive heat (heavy prolonged braking or a dragging pad). Some minor surface cracking is tolerable and can often be removed by resurfacing. But large cracks or deep cracks weaken the rotor and increase the risk of catastrophic failure.
SANDING ROTORS
This debate has gone on for years. Most suppliers of bench lathes and on-car lathes say sanding after turning is not necessary as long as proper feed rates and sharp lathe bits are used. The finish should be within specifications and cause no problems.
Proponents of sanding, on the other hand, say it improves the finish by making rotors smoother. Sanding knocks off the sharp peaks, torn and folded metal left on the surface by the lathe bits, and may improve the surface finish 2 to 5 microinches for better pedal feel, pad seating and overall brake performance.
Rotors can be sanded various ways. One is to apply a non-directional finish with #120 to #150 sandpaper on a flat sanding block. Hold a pair of sanding blocks against the rotor for about 60 seconds while the rotor is turning at normal speed on the lathe. Another method is to use a flexible ball-style hone in a hand-held drill to buff rotor surfaces (medium #120 grit or fine #240 grit). A third method is to use an abrasive pad in a drill, but some say this technique is risky because it is hard to do an even job and metal buildup on the pad may actually make the surface rougher unless a fresh pad is used for each side of the rotor.
The best advice if you do sand is to do it carefully, evenly and don't remove too much metal. A minute or less on each side should be enough.
A related issue here is whether or not rotors should be cleaned after they have been turned or sanded. Though few people actually take the time to do it, washing with hot soapy water can remove bits of metal that would otherwise end up embedded in the new pads. Those who do wash their rotors say it reduces noise comebacks.
NEW ROTORS
Should new rotors be given a "clean-up" cut before they are installed? Most rotor suppliers say no. Rotors are machined to specifications and are ready to install as-is from the factory. Resurfacing just reduces the life of the rotors and increases the risk of cutting runout into the rotors that was not there in the first place (if a bench lathe is used).
The flip side of this position is that new rotors may not be as perfect as the manufacturers say they are. Cleaning up the rotors before they are installed is cheap insurance against comebacks.
The comeback from the manufacturers is that quality rotors shouldn't need cleaning up. If there's a problem, it is only with cheap rotors that are inferior quality and are not manufactured to close tolerances. That's a good reason to buy quality rotors from a reputable supplier.
