miamisrt-10
- Joined
- May 24, 2006
- Messages
- 6
- Reaction score
- 0
is it necessary to change the rotors when you are changing breaks?
miamisrt-10 said:is it necessary to change the rotors when you are changing breaks?
Chuck B said:Have to add to Texas Yellow Fever...Clean your rotors with brake cleaner, sand then clean them again. Break-in is VERY important.....read the enclosed procedure with your new pads. A brake pad that is brought up to temperature too fast and not allowed to properly cool down can quickly become glazed and not perform as intended. Proper breakin causes a transfer layer (a thin film of friction material on the surface of the rotor) to be applied to the rotor surface. This will allow the brake pad material to rub against itself rather than having the brake pad rub against the bare rotor. You sand or turn the rotors to remove the old brake pad material and prepare the rotor to accept the new pad material. If you happen to glaze them you'll greatly reduce their effectiveness and only way to fix is to turn the rotors and yes buy new pads though some will argue you can sand the pads/rotors to help restore to new. I've seen many glaze their pads then continue driving pressing harder and harder on the pedal hoping their brakes will bed. This usually results in the pad overheating, delaminating and/or possibly warping the rotors.
Granted most of my braking experience was with my motorcycle racing days but brakes are brakes.
Stinker said:I think he needs a new dealer to go to!![]()
