JaysSRT10
VTCoA Board
This has always been a thought in the back of my head. Since I have owned my 10 I've wondered if I have an issue with engine performance. It seems like alot of you can easily break the rear tires loose in multiple gears. With mine however, in 1st gear rolling about 10mph or so if I mash the pedal to the floor I can get the rear tires to break loose the rear end start to slide to the right, then the tires hook and I'm launched. Only occasionally can I get them to chirp if I try the same in 2nd gear.
I bought a clutch kit I plan to put in this winter, as I've wondered if the clutch is slipping. I have 53k miles on it and only mods are BBK throttle body, K&N CAI and an X-metal lowering kit. I run 93 octane fuel and change the oil every 4500 miles.
