Bright lights With Fogs?
Tooloe
Central Texas
Has Anybody gotten annoyed by out Fog lights turning off when our bright lights are on? is there anyway to have both on at the same time?:dontknow:
its a common mod to wire the fogs to the heads
so that way u dont have to pull out the switch for them to come on
but idk if they would stay on with the highs:dontknow:
Brat said:
Got that right.:rock:
So is speeding. But we never do that. I just make sure I'm quick to dim the brights as soon as I see oncoming lights.
You got a great point there sir.:rock:
Just run a jumper wire from the ground leed on the running light module to the ground leed on the fog light module. That is what I did, and it worked perfectly.
Bill.
1. Remove the top of the fuse/relay box next to the battery.
2. Find the running light relay. Remove the relay and wrap one end of a 6 inch wire around the ground post of that relay. Reinstall that relay.
3. Find the fog light relay. Remove that relay and wrap the other end of the 6 inch wire around the ground post of that relay. Reinstall that relay.
4. Reinstall the top of the fuse/relay box.
5. Job done, time to drink beer.
Bill.
Bill.
Great little DIY :D
