BRIGHTER HEADLAMPS
avcts
Too Freakin Cold!
Anybody have any recommendations on brighter lamps for our SRT10's?
Something that doesnt require a rewire, just new lamps that are brighter.
The OEM High beams are freakin useless. I cant see $hit with them.:(
Thanks!
Silverstars or PIAA.
Sylvania fittment chart
2004 DODGE Ram Pickup
High & low beam headlamp
9007LL
9007ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9007XV XtraVision Halogen Upgrade: Up to 20% Brighter
9007CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3057
Stop light
3057
High mount stop light
912
Fog/Driving light
9006
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
License plate
168
Back up light
3057
Map light
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
212-2
Dome light
578
Trunk/Cargo area
912
Under hood light
561
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Wow...thanks!!!
the 9007XV would be the upgrade to a brighter light correct? Were do you buy?
Any benifit to the blue type? I know they look good...but are they brighter?
Thanks again!
I ended up with a set of Nokia Cosmic White Headlamps.
Not as good as the HID Low-Beams, but much better than stock and no 'lamp-out' light on the dash.
Got them here:
www.eautoworks.com
Forgive my ignorance, but I dont know what the HID's are?
Is that were you have to install a modulator/ballast?:dontknow:
High Intensity Discharge Headlamps.
Yes, they require a modulator/ballast thingy which needs to be mounted behind the grill/headlights.;) Though, they ARE plug and play.
When I had mine, the low beams are friggin' excellent, but the high beams are even worse than stock, and I did have a 'lamp-out' light on the dash each time I started the truck. The 'lamp-out' light can be turned off by simply turning on the headlights for a second and then turn them back off.
I never use my high beams anymore. I still get people high-beaming me thinking that I still have mine on (since they are so bright). Conventional lights don't compare, but there are cheaper upgrades over stock.
Boomer has them and is working on a fix for the "lamp out". :D
My set up has NO high beam whatsoever... and the Lamp out light simply flashes upon start up, at which point i turn my lights on/off and it goes out!! At night their like night and day over a standard halogen. Once you have em you'll never drive with any halogen light again!! :rock:
Here are pictures of silverstars installed in my truck. The left (drivers side) light is a silverstar and right is stock - john
sweet info...thx John!
avcts said:
Were do you buy them John?:confused:
Pep boys? AutoZone? Advanced?:dontknow:
Both have Silverstars.
the PIAA's are much brighter than the silverstars....lined up 3 trucks at the track 1 w/ OE, 1 w/ SS and mine with piaa....piaa = alot brighter.....
EBAY.....50% off retail...3 day ship
Had a storm here...lost power for 4 hours.:(
Is it possible to get the PIAA locally? I haven't looked at all for headlamps.
Thanks for the info!!!!!
I went with the Silverstars before switching to HID`s.I would in retrospect go with Piaa`s if not convertiing to HID`s.
Just for shits and giggles, I went to Pep Boys and bought Crystal Hyper White by 3A Racing Performance. Part number 46-9907.
Damn OEM are significantly brighter. WTF. Shined the beams on the garage wall. Oem is noticable brighter. Not quite as blue/white but brighter. These were $42.99.
Dont buy these pieces of $hit.
Now I have to go back and waste fu%^in gas.:mad:
