05 dodge there are a few things to take into consideration, one is the bearings, you need coated and grooved mains for one.
but on the rods you have multiple choices, I can provide k1 rods, eagle rods in two choices, 1000hp and 1500 hp, and even the allmighty oliver rods, capable of whatever hp you thro at them.
from cams to timing chains, even get your heads ported and polished.
Also can provide the ARP head bolts, and main bolts, and provide billet mains to strengten the bottom end.
as well I have reputable builder and machine shop that is even a respected member on the board here.
If wanted we may even be able to build you a motor and after its done do a swap with you.
As far as around 700rwhp, there has been a few here and there that have come mighty close to the 700 mark, I think with the right combination it is possible.
Just let me know if I can help sir
