Built tranny on ebay
Troy's QC SRT
Virginia
The level 4 RAMZILLA transmission comes with four sets of Alto Red Eagle clutches and Kolene steels plus a direct 7 clutch PowerPack, high capacity extreme duty 5 clutch billet direct clutch drum (7 clutches with the PowerPack), 7 overdrive clutches - - a 40 to 75% increase in apply area, 5 forward clutches which is 25% more clutch apply area than a 48RE, all three 48RE 6 pinion planet gears, front, rear and overdrive, the .055" thicker 48RE sun gear shell, the one piece Sonnax 300M hard input shaft and hub, performance 3-4 accumulator spring for a firmer shift into overdrive, high performance low / reverse servo, cast aluminium accumulator piston, performance intermediate servo cover, a 5 to 1 intermediate band apply lever (4.2 gas), extreme duty brass impregnated carbon fibre flex band and a heavy duty intermediate band strut. A special manual valve allows converter fluid charge in park. It has the stronger Mega Spring for overdrive direct clutch apply with more holding power in reverse, 1st, 2nd and 3rd. It comes complete with a deep finned cast aluminium pan that holds 2 extra quarts of fluid. The heavy duty / high performance torque converter that comes with this package is set at 1800 RPM stall. This transmission is good for any type heavy duty / high performance use up to 800+ (gas) horse power using pump gasoline, towing, 4WD, high performance and others. The RAMZILLA transmission has 20 major performance upgrades. The best 48RE transmission on the planet. the gas 48RE transmission comes with a 10 inch billet lock-up torque converter.
This is the best aftermarket 48re available, OEM replacement fitting for Viper V10 Rams. Pick up or we can arrange shipping at buyers cost
http://cgi.ebay.com/ebaymotors/Custom-SRT10-Dodge-Ram-48RE-Auto-Transmission-RAMzilla-/200493054857?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item2eae513b89#ht_500wt_1182
Oh no Nick I wouldn't buy one at all bro!!! Go through suncoast, HTS or ATF speed only......don't mess around with any other places that say they can build it....Others on here have had bad results from "local" shops....Some haven't had any issues but me personally wouldn't chance it.....I only posted that just to see what people would say about it!
its funny to see how many of thase members are banned lol and the last oneto post on it lol!!!!
haha...i was thinkin the same thing:D
according to the bio...he's not even 30? is that true?:dontknow:
