Bullet style mufflers?
Black1
On the dark side of the road
Anyone know where I can get a SMALL bullet style muffler/resonator? I need 2 1/2" inlet/outlet. I'd like them to be under 13" long (overall).
Prof - Do you know what brand Westech used to replace your cats?
Tony - HELP! lol :D
Tony - HELP! lol :D
Does this help you?
http://www.summitracing.com/search/Department/Exhaust/Section/Mufflers-Resonators/Part-Type/Mufflers/?Ns=Rank|Asc&autoview=ProductName
i have them under my vette instead of the stock end muffler.... was to quiet for me...... tryed 1 each side but that again was to loud... so ended with 2 each side .... just perfect ;) :D
can post later pics if you like :rock:
My resonators were MagnaFlow...they may work perfectly for you...and I think they come in a couple of lengths...
Roy
Roy
Thanks, Roy... I want to put them in front of the crinkle-tubes (in, what you could think of as, a "cat location"). There really isn't ANY room on the outlet side of the crinkle-tubes (basically the same tubes used in "side exhausts", only they exit out the rear of the car). So, I need something pretty small...
.... The tone is good now, except for a real nasty drone/cackle during certain RPM's. Otherwise, I'd keep what I have. ;) But, the junction between the midpipe and the crinkle-tubes on the driver's side is all jacked up and needs to be fixed... I figured I would have the exhaust shop weld in a couple resonators while it was there. :dontknow: :)
Norbert - PLEASE post pics of your setup, if you can. :rock: :eek:
Not much Jake...but they killed the high pitched drone...the ones I put on were longer about 12 inches...
