Will the front shocks bottom out if i cut off the oem front bump stops and replace them with flat ones?... the front is stock height btw.
Because factory almost sits on bumpstops. You'll get a bit better ride especially over bumps. Won't hurt a thing. We remove entire cup and rubber on 2-3" drops in front without ever bottoming out.:burnout:
I'm not 100% sure so don't quote me. I would think that the shocks or worse yet the control arms would hit something that they are not designed to. You also have the possibility of the front tires may hit the fender/liner.
I have these. Much better. I dont bottom out and they help out with bump steer a little. Those poly ones are just to hard when the control arm hits them on a bumps
Belltech 4923 - 2.5" Outer Diameter - 2.01" Tall - Bump Stops & Suspension Bumpers
he said he's at stock height...
i just don't see the point in it...
