moparracing said:i usually burnout @ ~2500rpm for less than 10 seconds, just enough to get alittle smoke off them & heat them up..... the M&H's don't really need a massive burnout to be affective, just enough to scrub them off...... i run about 22 psi in mine.... linelock helps a ton too....... if you don't have, you should consider jmb's kit. :rock:
mysrt10 said:http://www.hubcap-tire-wheel.com/ they were a little pricey but, every other company i tried to go through said they were permenately out of stock or they didnt know when they'd be avaliable again.
i went into my local americas tire & got my eagles for $129.00 a rim.TNVIPER said:Where did you find the rims? Another member here is search for the eagles..
HISS said:Best launch that night 12 psi 1.68 60'
The Itch said::dito::dito: Just be ready to clean rubber from the front to back of the truck!!!I've been experimenting with the pressure in mine. Last night I had a 8.41 in the 8th with 22lbs in the tires - no hop or chirp but I'm running a QC with an automatic...:dontknow: BTW 8.41 is good for me...
505'sFastestViper. said:
